I didn't buy a car charger lead. Does any body know the polarity of the centre pin ? Is it centre positive?
Thanks
Yes, center is positive... You can find it in ebay for less than 5$
SFMI4UT
24 hours is definitely not within specifications for the charger. I used about 11 hours to charger 4 x 3100mAh batteries.
What voltage is the 110V exactly? In my test it is 107V and only 50Hz
Were these batts old/used? My understanding was that new Li-on batts would measure around 3.6v when new/before charged up.Hi HKJ, I just receive 4 panasonic 18650 3100, all comes in 3,16v put all four in the charger at 2:25pm full charged at 8:40pm cutting charge at 4,19v using the 12volts DC connection with a external power supply.
I check the AC voltaje and is 109v 60hz
The next time I will use the AC connection to charge all four to test the charge time.
I think too that the old 4 batteries that I charge the first time had a high internal resistence.
SFMI4UT
Hi.
Should the battery`s be put in the charger before plugging it in or after, as it charges at 750ma for two and 375ma for four, because if you are charging four, and start putting the battery`s in after the charger has powered up, will it not confuse the charger?
Either way, the charger is checking both slots all the time and will change charge current as needed.
Is this with the old V1 charger or the new V2 charger?
The manual does warn about charging a single battery (aaa or 10440).
