I respect your opinion. Look at the 4sevens minix, it has a runtime of am hour on high. I'm also not convinced that the jetbeam is ANSI lumens.
Sent from my iPhone using Tapatalk
Yes, the RRT-01 running on a rechargeable 16340 with 3.7 volts and 750 mAH, does indeed output 500 lumens OTF and 20 minutes of run time to ANSI FL-1 standards.
The reason why the 4Sevens Mini-X only outputs 210 lumens with a whopping 1 hour run time, is because it is recommended to run on disposable primary CR123's at a lesser 3.0 volts, yet a greater 1500 mAH's capacity only.
Not only does the disposable primary CR123 have a lower voltage for less power, but the internal resistance of the disposable CR123 is also higher, meaning that the disposable CR123 has a lower discharge rate, ie a lower amperage, for a lower lumen output again.
Thus the Mini-X has only 210 lumens.
However, the disposable primary CR123 does hit back with a whopping 1500 mAH capacity, for longer run time...
