Looking at the power your panel supplies I really wonder what size they are. Most panels can get you around 100 W / m^2 (in direct sunlight... any cloud makes numbers drop like a rock), so you get roughly 10 mW per square centimeter. That probably is enough to drive a power LED, albeit at a very low power, so it won't be visible from a distance unless it's completely dark. Still, if I look at the thread here about XM-L at low power you should get several lumens from it.
I'm using solar panel for indoors... This is why i have these properties.
And it's a very efficient one.
Yes, i have 325mW and i can add some together but i see that it won't help a lot.
I could add 10 or so...
What if the LED will blink like 0.5 second off and 0.5 second on?
Thanks.
