sdl13
There is a lot of confusion about the "B" mortality number.
Philips Lumileds defined mortality as performing below the designated lumen maintenance. So if L is defined as 70% (L70) then a failure would occur when performance lumen maintenance is below L70. There is no distinction between a catastrophic failure, say from infant mortality, or if the failure is simply a due to lumen degradation. Either way, performance would be below the L designation. In some cases an application may require L80 or L50, so there are many B/L combinations that could be calculated.
There is a white paper that explains all this and gives the statistical methodology and it can be found at http://www.lumileds.com/pdfs/WP12.pdf
