angelofwar
NO SURRENDER, Farnsrocket!!!
To Wcleexh0: How long did you have the damaged P60L for? as it seems to me that you may have burnt the LED. The P60L (I think) was discontinued as a result of its relatively poor heat disipitation because it only heatsink is its reflector; since it was used in a G2 with a nitrolon bezel it may have just been too hot for the LED to handle.
The Malkoff dropins are much better then Surefires P60L's as they are both more efficient and properly heatsinked but cost almost double; same deal though, don't use the high powered dropins in plastic bodies lights.
Jeremy
The P60L's weren't much to begin with...one reason they were discontinued. If it happens again, contact Surefire, and they should send you a KX4 to replace it, free-of-charge. Since you don't have to send the bezel back, get a Malkoff drop-in for it, and you're set. You'll have a bomb-proof light (6P + Malkoff), and a nice back-up LED assembly (KX4). You could even get a cheap G2 body off the MP for around $20, and have two lights.
Hope this helps!
My wife, 3 kids, & I went on a day hike at Petit Jean Mountain here in the Ozarks a few months ago. It was getting late in the day, but we decided to take a trail down to a waterfall. Round trip we thought should be 2-3 hours which would push us close to dark. I had 3 flashlights in my pack, so we were covered. On our way back it did get dark, so I pulled out my Zebralight SC30, my Fenix P2D Q5, and my Fenix LD20 Q5. The LD20 would not turn on. I banged it around, and it flickered only. The head of the LD20 worked on the body of the P2D no problem, so the problem was somewhere else. The batteries were fresh lithiums, so that wasn't it. This was very frustrating because it was getting late & we had a ways to hike. We managed just fine with the two lights, and I knew I had back up batteries (so no real worries.) But still with 5 of us hiking up a steep trail, the third light was needed. My kids did complained a bit as my wife & I tried to light things up for everyone.
I got the light home the next day, and found that in the tail cap there is a silver cylinder with 2 dimples in it that had become loose. This cylinder can be removed so that you can change out the tail switch & boot. I simply tightened it, and it worked just fine. I now have a better understanding of how this light works.
Since that happend to us, we now hike with five small lights at all times.
This is common with a lot of lights, like Fenix and 4sevens (my HDS rotary has one too). When I get any light I clean it and lube it and then I tighten that retaining ring down real good with a small pair of needlenose pliers (I didn't do this to the HDS).I got the light home the next day, and found that in the tail cap there is a silver cylinder with 2 dimples in it that had become loose. This cylinder can be removed so that you can change out the tail switch & boot. I simply tightened it, and it worked just fine. I now have a better understanding of how this light works.
I got some pics of that waterwall...beautiful place indeed...can't wait to make my way back up there...been a few YEARS! Devils Den and Lost valley are also nice places to use any newly acquired lights you may have...
TwitchALot said:Quark Mini AA Warm White failed to turn on a couple of days ago. I don't use it too often but check it once in a while, and it didn't turn on the other day. Contacts were cleaned, spring checked, battery replaced, still no good. No known cause of failure - hasn't been dropped or used much. Sending back for RMA.
