ChrisGarrett
I got my Keeppower 3500mAh batteries before I got the MD2 that they were destined for so I pulled out my old MG L-mini and discovered that the batteries wouldn't fit.
Are 18650's wider and longer than they were 8 years ago?
If I want to start using an 8 year old 18650 light, do I need to get a modern 17650 battery to use in it?
--flatline
Protected cells add width and length to the base cells. You have the protection circuit that has thickness and you have a button top usually, which also adds to the length.
Couple those with a second wrapper (usually) and the metal strip, albeit a thin one and you've got a few hairs' worth of diameter, which may be problematic for older lights.
Chris
