Could you see if there is any significant difference in the output brightness on high when using a CR123 (or 2xAA) versus using just a single AA? :thinking:
The reason I ask is that in this post:
https://www.candlepowerforums.com/posts/1894473
the manufacturer gives a table showing the current levels for different input voltages, and it appears that there would not be much difference between power consumed at 1.4v (approx. = 1.386w) and power consumed at 3v (= 1.47w). The big advantage, for me, of using the CR123 and 2xAA bodies would be not the size of the package, but the greater output at the higher voltages. If the power consumed remains roughly constant at 1.4w with all the different voltage inputs from 1.4v through 3.8v (see table at link above), then all that will really change is the runtime. This would seem, to me at least, to negate the advantage of the extra battery input options.
There would be no real need for a CR123 tube or a 2xAA tube since I could get the same result by carrying the light with just the 1xAA tube and an extra AA battery.
The beamshots of the M3 with 1xAA versus the M3 with 2xAA in this post...
https://www.candlepowerforums.com/posts/1904550
although not side-by-side, still seem to indicate what I have speculated: that there is no real increase in brightness with the extra voltage.
