I'm really curious how the burn in is going. Any results yet?
Thanks!
So some questions:
IMR 26650, do I have to use this sell to have same results as you when desoldering the two wires, or will I get same results with the 4S original cell?
"3) 15min cool down restart shows that DD output remain the same while Factory is now brighter"
Do you mean that both lights where cooled down? And why is factory brighter ans for how long does this maintain?
So why did 4sevens made that regulation if no harm is done to the diode in DD?
Thank you, what I´m not sure of now is how/what you do to make it DD? I'm missing something here. What kind of steps is necessarily?
Also,
"De-soldering the two little wires to the little resistors just deactivate the thermal sensor"
and
"The factory is brighter because the light cooled down so thermal regulation is less aggressive."
Should't the modded head be as bright as the factory in the above? I mean, because it doesn't have any connection with thermal sensor? I'm a bit confused with this...
I see, any tips on where I can read on how to mod it to Direct drive? New with this things...
Dear Vin,
I don't know how far you've gone in disassembling the S12 and the tailcap but I had a few questions:
1) If we try and put a FET switch in there (I believe one was being sold in the custom section of CPF to replace the McClicky) to handle the amps (I assume it has the same thickness as a McClicky) will that work? Or is the McClicky too thick, thus causing the tailcap to possibly bottom out on the battery tube sooner and leave tailcap threads exposed?
2) Is the electronics at the head removable? The LED appears to be held in place by 2 screws for centering it but what about the circuitry behind it?
3) Can the circuitry be changed from 2 mode to 3 mode?
Thanks again for your input.
I can give u tips. But u should not dd unless u gonna burn in the led
vinhnguyen54,
I have been really busy as of lately. I still have those CR123 NiMH cells I will send you so, you can burn-in that SST-90 and double those OTF lumens and report back with your findings.
I will try and go today to the post office and you should have those cells by Friday/Saturday. I need to see you finalize this project as I am really intrested in seeing a S12 Maximized to its full potential.
