Justin Case
- Joined
- Mar 19, 2008
- Messages
- 3,797
IMO, a really nice advantage of using the JimmyM driver is that you can load up on a big battery stack to drive your hotwire, thus giving you lots of run time. For example, in direct drive, with something like the FM1909, you are limited to 3xLi-ions such as 3x18650, 3x26500, and 3x26650. But with the JimmyM driver, no problems loading up a 4D Mag, for example, with 5x26500 to run the 1909. You get regulated output and 5 cells vs 3 cells of battery power. Similarly, instead of running a WA1111 on 2xLi-ion, you can load a 2D Mag with 3x26500 for example and get 50% more battery capacity. Of course, this is not an perfect apples-apples comparison. You could run the WA1111 in a SureFire M6 using a 2x18650 holder, and that host is smaller than a 2D Mag. So to get the greater battery capacity, you also have to move up in volume.
I pack the top of my Mag switch with some ceramic fiber insulation. This is one source.
