Someone, think Lasercrazy told me using 10 ga unsoldered wire just wrapped around both ends touching the tailcap when spring snapped in and touching the bat. neg when tail cap screwed in. works as well as soldered.
I've tried it,unsolder, on several and works.
Jim
Thats what I did in a C tailcap
At the base of the spring, I wrapped wire around in a loop, slid it round to near where the end of the spring finnishes. This is a pinch point and holds the wire firmly in place.
Put the spring in the tailcap, and it is held fast.
I needed to make up a little space in my mag mod as the cells I was using came up a little short, so I used the "crown" or bit that you see at the top of the switch in the first picture in this thread, that screws on and holds the lamp into the holder, ( I used a kiu so I didn't need this bit) and pushed it on the top of the battery touching end of the spring. I then looped the other end of the wire, that I'd attached to the base of the spring around the top, and the fact that it snapped on the top of the spring held it in place very well.
I'm guessing it works as well as soldering it to the spring, why wouldent it.
The only thing better would be to solder direct to the tailcap, and bottom cell but that wouldnt work for removing the cells easily.
