Northern Lights
Using de-soldering braid I ran a piece from the bottom to the top of the spring. I roughened the inside of the cap and made sure the cap threads were clean for good contact.
The braid I wrapped around the spring wire and soldered the braid closed. The braid is soldered to its self and captures the spring wire. The braid makes contact to the cap and to the bottom of the battery. The spring holds it in place is all.
You must heat it too hot to solder it to the spring in most cases which changes the spring temper.
Over the years I believe I have showns with the many experiments, mods and posts the 5761 puts out a bigger and beam and more lumens than the ROP and teh ol' '85 at only 7.2V!! Your ROP will benefit with the mod.
I found this modification and a modification to the switch to be very beneficial in providing more power to the bulb.
Have fun and look forward to building more and brighter!
As an after thought, a picture. The bottom connection shows the wrap. It is turned around for the photo. The top is isolated because the circuit has a fuse. The second photo shows an alternative to the spring. link: 2C Mag Tail Cap mod for AW's "C" cells and link:
Tail Cap Spring Substitution Solution!
NL
NL
