electricmonk3000
- Joined
- May 22, 2014
- Messages
- 5
Hi all,
I have read so many posts over the last few days and have a tonne of information swimming in my head. Rather than posting multiple questions in many old threads I thought it prudent to make a post of my own.
I have two magcharger flashlights they both run Intec 6V 3.5AH battery packs which are now about three to four years old but seem to be ok.
I have been using the stock Magcharger bulb but buying here in Australia can cost up to $25 dollars each. And lets face it. The don't last too long in a high shock environment. (Jumping rail lines in a vehicle, being thrown at people)
I was thinking of the LED conversions, but don't think they suit my needs very well. I often go into abandoned warehouse size buildings with no lighting and railyards (again with no lighting). I need a little flood but as the vehicle has spotlights that is not a huge concern. (I would like to keep ability to adjust my mag for throw or flood though). As we often chase people who are up to 200m away throw is my main concern.
I have tried searching for the recommended bulb upgrades and have found the Philips 5761 in a local store..At $26 each. I have found the other bulbs and the 5761 online but when you add shipping they become more expensive.
I would like to try an extension to the housing so I can fit six of the 1/2D's for 7.2V But even for that I am having trouble finding the 1/2D's at a decent price. I have seen a lot of talk about fitting in AA's in cradles. Can someone please tell me what I would need to do this? (In simple terms though and I would like to keep the light to a minimum of it's stock length, longer is fine) Bare in mind I have ham fisted soldering skills. Or is there an easier solution than the 6 1/2D/AA route? If it's too hard I know I can just run the stock battery but just looking for the comfort of a little more run time if needed.
I have only one charger and that came with one of the Mag's I got second hand. It's not genuine and the specs on it are: Digitor 100-240V, 50-60Hz, 180mA, Output 12VDC @ 0.7A max. I know the specs don't all match up with the genuine charger. I have yet to find one of those online for (again) a decent price. Any recommendations for what to look for in a replacement?
I have no problem leaving the torch for 12 hours in the cradle between shifts. But if I change the battery config it looks like it will take much longer to properly charge if I can still use it at all.
For now (If they are available) I will be getting Fivemega's ceramic slug mod, MOP Aluminum reflector and the extension if needed.
Thanks to anyone who can take the time to read through that essay and respond
