Can't. There is no more space to add even .003" shrink tubing (times both sides for .006") and have the loaded cartridge fit in the tube.
Strip the original wrap.Can't. There is no more space to add even .003" shrink tubing (times both sides for .006") and have the loaded cartridge fit in the tube.
If the cells were in parallel, there would be no issue when any case touched any other case but since they are in series, there are different voltages at any given two different cases. The moment the two battery cases in the two forward-most positions in the carrier touched the body, there was instant arc and much heat and a tiny bit of smoke.BVH: My CGRs the same as yours, with the fully exposed bottom. I don't see why it will be a dead short scenario as the whole body of the cell and flashlight is negative current, only the carrot/button top/positive contact spring the only positive current right? I think the exposed bottom would only be a problem with protected cells where they have that conductive strip that connects the PCB at the base to the positive on top of the cell?
Bugger... I'll use AW IMRs then.
Unprotected 3100mah cells are not "safe" chemistry cells like IMRs and CGRs. Using 4 in series could seriously be tempting fate. I've tried to squeeze protected Xtar 2400s and 2600s and they could not fit because they were too wide.
I am using x4 Eagletac 3100 - they fit perfectly. It says IC protection against over charge or short circuit protection.
Mohan
The battery fit situation is so bad with this light it's almost in need of a battery compatibility specific thread, as in the case of the TM11.
I can 'wedge' 3000mah Ultra-Fire cells in mine but they're very tight, not to mention they're fire cells.
Redilast 2900mah cells work.
Eagletac 3100mah cells work according to Mohanjude.
Kallie's CGR 2250mah cells don't work according to BVH
So have you heard from them again? Have they shipped the 65W version yet? Maybe there's no such thing as a 65W MagicFire, only 40W Magicfires, and everyone got cheated. Please do report back when you receive the "65W" version. Thanks for being an early adopter, so we can learn from your mistakes or otherwiseOK - the gremlins have struck again... I thought this HID looked identical to the 45W.... side by side was no different. It looked really bright - but then I had forgotten that the 45W HID was not a bad light at all. Putting them side by side after having charged the 2nd set of 18650 gave me that sinking feeling. I have now had confirmation from Rick via email that the 'shipping department' has sent me a 45W by mistake instead of the 65W. So here we are with a another false start. He has promised to put it right with no cost to me. He is hopefully going to ship the '65W' light in the next few days as it sounds like he hasn't got one in stock. I am sorry to have got off to this false start but these things do happen....
