hagbard, that far along, the C9000 was interupted during the second, and final charge. I would just charge them up and use them. The big drawback is that you don't probably know what the final capacity was, unless you happened to notice. To get that, you'd have to start all over again.
Dave
Okay, I guess this brings me to yet another question, what is the "charge rate"? Haven't charged any batteries yet. Is it the rating on the battery or the "discharge rate"? They're eneloops rated at 2000mAh.
I normally go with a charge rate of 500ma or 1000ma depending on how quickly I need the batteries.
Okay, so the charge rate doesn't really relate to the capacity of the battery, its how much juice is being delivered at a time. I'll still get the full charge, correct?
Hello Hagbard.
Welcome to CPF:wave:
1. Set it at the rated capacity, 2000 mA with your cells.
2. Thats normal.
3.When you are not in a hurry, set the charge rate at somewhere between 0,5-1,0 C. With your type of cells (2000mAh) I would have choosen 0,5-0,7 C which is with your cells 1A- 1,4A per cell.
If you dont touch any buttoms, the charger charge your cells with 1A which is ok with your cells.
Anders
The above is just my opinion based on the reading I have done here and elsewhere.Originally Posted by hagbard View Post
Just bought this charger, and I'm a total newbie and find the instructions a bit confusing, so I'll blast off a few questions:
1. When using Burn-in, it asks for "Set Battery Capacity". Would I be right in assuming I set it to the stated capacity on the battery, which if 2000mAh I'd set it to 2000mAh. Asked in another forum and they said set it to 1000mAh, which is the discharge rate?
You set it to the actual stated capacity on the battery label, assuming it is more or less accurate, which in the case of quality batteries is usually the case. The value is used by the charger to calculate the rate at which it is going to charge during the break-in cycle.
2. When completed my batteries have reported voltage of 1.46v not 1.2v, is that normal? It's normal for the batteries to come off the charger a little "hot" (as in high voltage, not temperature). Once a load is applied, the voltage will sag to expected levels.
3. When using "Charge" do I manually set the "CHG Rate" to the rate printed on the battery, use the settings it sets up automatically, or the "discharge rate"? The general consensus, I believe is that it is optimal to charge at about 1/2 C or 1/2 the actual capacity of the battery. So in the case of a 2,000 mah Eneloop, you would charge at 1,000 ma which is the default the C9000 is set up to charge at if you don't enter anything. If you are in a hurry, it's acceptable to charge at a higher rate, but it's best for the battery to charge at .5 C. Too low a rate and you risk the charger missing termination. Too high a rate and you risk damaging the battery or shortening its useful life. So .5 to 1C is the usual accepted appropriate range, for NiMH and NiCad, imo.
thanks.
It does, it just takes longer to charge when at lower rates.
(I read your ORIGINAL, unedited post too.)Thanks, that was helpful .
Then just insert them in the C9000, give it about 4 or 5 hours and your batteries will be charged. Then simply remove your batteries and use them. Despite your statement above, this will work unless your C9000 is defective. But I believe your C9000 is fine and you are simply misinterpreting how it works and what the display is doing and the timings involved.I just want to charge my batteries with a minimum of hassle, not be be an expert. I just tired doing the Charge mode, and put in three batteries, every time I do, it sends me back to Mode. Its not accepting more than one battery.
whatever the default is for AAA batteries (probably 400 ma)
What Eric told you is correct, but it might not be the only problem.Here's what I'm doing:
1. I put an AAA in slot one, Select Charge mode, press Enter, select 400mAh, press Enter.
2. I then put an AAA in slot two, Select Charge mode, press Enter, select 400mAh, press Enter.
--> it now goes back to slot one and asks me to select the Mode again?! If I put all the batteries in, go from slot to slot doing the above, it looses all the settings. I think its not working.
I just want to charge my batteries with a minimum of hassle, not be be an expert. I just tired doing the Charge mode, and put in three batteries, every time I do, it sends me back to Mode...
This is not true. If the MH-C9000 'blinks' and continuously returns to MODE, it will *NEVER*, AFAICT, attempt to charge that cell.Then just insert them in the C9000, give it about 4 or 5 hours and your batteries will be charged...
This is also not true. The MH-C9000 will default to a Charge Rate of 1000mA for *ANY* cell inserted into *ANY* channel that the USER has not changed / programmed before the timeout period expires. IMHO, based on the knowledge I've gained from reading the CPF 'Batteries Included' Archives, 1000mA (aka 1.25C) is TOO HIGH of a Charge Rate for 800mAH AAA cells....Just trust that the C9000 will charge your AA and AAA batteries more or less properly with no intervention or input needed from you beyond simply properly inserting the batteries into the charger. Everything else will be taken care of automatically and the charger will use its default charge rate of 1000 ma for AA batteries, and whatever the default is for AAA batteries (probably 400 ma) and that will be fine for most NiMH batteries you are likely to be using.
Some AAA batteries have a wrapping that curves around the end of the negative end of the battery, and this can prevent the C9000 making proper electrical contact. (Only happens with AAA cells, not AA cells.)
Basic, NO FRILLS / NON-TECHNICAL answer:
When the
More Technical / Informative answer:
CLICK
