Hello! I have registered here to follow this magnificent, state of the art thread.I have more than strange experience with thee C-9000, so I would like to share some with you and ask a few questions.I currently own the C-9000, with 0L0EA written on the back of it.
My first two C-9000 chargers had died, when trying to charge cells, that had been discharged to the maximum.I first did some disharge, then rest, then discharged again at 100 ma.Fortunately, this is no longer the case, but I am struggling to ressurect some old cells...I have run over 10 break-ins and there was no capacity increase.
I have 4 X AA from LIDL, TRONIC 2500 mAH.They were charged best at 700 ma, anything else resulted in about 2100 mAH final capacity, while charging at 700 ma did reach the advertised 2500 mAH.They were dirt cheap, something like 4 $ for a pack of 4 cells, and I got two packs.It has been only a year and 3 cells showed HIGH.I then mixed them with healthy batteries in the torch, drained them all, and I was able to squeeze about 2 months more usage, before finally tossing them.Now the rest of them reach about 1800 mAH.
I have Varta LSD Ready 2 use, they are advertised as 2100 mAH and now a couple of years old.They also reach about 1800-1900 mAH, and one of them reaches only 1500 mAH.Since break-in does not help with both Varta and Tronic, could you recommend any solution? C-9000 allows up to 12 cycles.Maybe this is what I should do ?
