Yes, M361 usually has a bit more output than M61 variants...this might explain why it seems a little brighter.
Are you measuring true low mode or low mode using H/L ring. I faintly remember a really low draw on low but not that low....maybe I just can't recall.
I imagine if you want low output for long runtimes; many of these modules will give you what you want. I was browsing some graphs last night/beginning of the day and saw some crazy low mode runtimes from various modules/lights including hound dogs.
we have so many options outside of what these lights were designed.
M61 could run on single cells or 2x eneloops but those tests are not for me....maybe one day when i have nothing to do for days. or If i let a test run while i'm out on the road. i did that once in the past and whatever module it was ran longer than I was gone IIRC.
I also want to test some modules with a modified H/L ring set to 50lm. I think i have done that in the past for woodswalker. My reasoning is this... M31L/LL or even M61; instead of having 2 modules; I can take the higher output module and set Low to match the other module. This in theory should give me both modules in one. I would lose true low mode but that would be ok, or just swap H/L rings.
I want to keep 1 M31 as i am not the biggest fan of 3v. M31 LL 219b is around 50lm I think. M31L 219b is around 125lm. If I use this in MD1 with H/L I would set low to match M31LL 219b. I think the runtime would be close enough to matching the true M31LL 219b. Both are great modules and make it difficult to choose. I need to see if i still have my H/L ring to make 50lm on low. I can then compare current draw. Anyway, you get the idea. I normally don't care about the low output modules. M361 can give me the modes i need. M361 gives me full usable output, a good general output, and good low, low low modes.
I also think an M331 would be a great idea for 123/eneloop. I don't care about runtime, like many of you. If i can get an hour or 2 from a module; I'm good. 1hr is typically good enough for my use. Okay...I'm done rambling for the moment
