Manker MK38vn - Brightest Full Size Popcan R (Pre-Order)
Skylumen
Purchase Here: https://skylumen.com/collections/v54-lights/products/manker-mk38vn-brightest-full-size-popcan-r
Coupon code "MK38OFF25" = 25% Pre-order discount
A)
Stock SFT40 6500K @2s 16,500L, 500Kcd, 1414m
B) Stock XHP70.2 6500K @2s 34,000L, 120Kcd, 693m
C) Stock XHP70.2 5000K @2s
D) MK38vn XHP70.2 6500K SDCE @2s
E) MK38vn P70 HI 6500K @2s
  • White is beautiful but gets dirty quick
  • XHP70.2 = clean beam with soft hot spot to spill transition & negligible petal effects due to multi reflector wells = No Turbo below 11V/~50%
  • SFT-40 = Noticeable petals effect at close ranges but filled hot spot and great beam otherwise = No Turbo below 11V/~50%
  • Manker's best build quality to date
  • Handle firm fitment but easy removal with included tool
  • Handle Fans operate independent of light functions
  • Battery state LED indicator on main button
  • Attractive dark chrome trims
  • Hefty 2lbs with cells and handle installed
  • Quite fan but functional airflow
  • Light is balance and natural to hold with or without handle
  • No built in USB-C charging for individual cells version
  • Excellent UI:
  • From OFF: Press and Hold = Moonlight
  • When in Moonlight Press & Hold = ML1>ML2>ML3>ML4>ML5 (Last mode memory)
  • From OFF: Quick Click = ON @ last mode memory
  • From ON: Quick Click = OFF
  • From ON: Press & Hold = Low-Med-High
  • From ON or OFF: Double Click = Turbo
  • From ON of OFF: Triple Click = Strobe/Disco Group (Always start @ =Strobe)
  • From Strobe: Press & Hold = Slow Blink>SOS>Strobe
  • Handle forward button = Fan ON/OFF
  • Handle rearward button = Duplicate main button UI
+ "V54" Engraving
+ Extended Warranty
+ Shipping Signature and/or Insurance (NOT INCLUDED BY DEFAULT)
+ Specifications
Must Read Purchase Agreement
HC/AHC/PAHC Sample
[email protected]
b8llzblue
Are those beam shots in stock form? The sft40 edition looks great!
Will we see vn beam shots and the p70vn version?
1SICKLT1TA
Much want! Next time you are doing beamshots can you do something like the k65gt against this Sft40?
Skylumen
K65GTvn is a pencil beam thrower relative to this MK38vn with SFT40.
I am waiting to P70 LEDS to arrive so I can do a video review on this light.
  • K65GTvn SBT90.2 5700K DL #2s: 5150L, 830Kcd, 1822m
  • Stock SFT40 6500K @2s 16,500L, 500Kcd, 1414m
Yeah, I can imagine the K65GTvn would have a much narrower pattern, however the throw numbers don't seem thaaaat far apart. Once you start talking 500k... 800k... its just a level up isn't it? The bigger the numbers the less notable the increase as it's a smaller fraction of the overall number.
Can't wait to see pictures/videos of this new P70 LED in action!
Skylumen
830Kcd/500Kcd = 1.66
1822m/1414m = 1.29
100Kcd = 632m
400Kcd = 1265m
66% more intensity only equal 29% more beam distance. You need 4 times the intensity just to see twice as far due to the square root function.
Our eyes sees beam distances so yes the difference wont be much. However the difference in 3 times the output and and a much larger hot spot will make a huge practical difference.
Our eyes apertures also step down to protect itself so we see even less percentage of lumen the more lumen we have hahah
SKV89
Wow the XHP70.3 HI even have 90CRI down to 2700k! Would love to see this emitter in one of these lights.
