Members' experience by brand with leaking alkaline cells.
alpg88
Nickel cell do leak, but the number is negligible compared to alkaline cells.
Dave_H
Ottawa Ont. Canada
Does this apply to NIMH cells that subjected to over current? I can see that some lights that are dual AA and 14500 could have settings above and beyond the current outputs of NiMh cells that appear to work, but are in fact frying the NiMh cell.
Just asking...
GL
I don't know about operating over-current causing venting but imagine if severe enough it could.
I've charged NiMH in fast chargers which made the cells hot (not a good thing) but have not seen venting so far. OTOH I've seen some end crystalization on NiCd and NiMH in solar garden lights where the charge current is low; so must be heat in summer or just low quality of the seals (and overall).
Dave
N8N
I feel like this is mostly an issue with off brand batteries. I have used energizer and duracell with no probelms of leaking. The brand that seems to leak the most for me is amazon basic brand batteries or any AA that come with chinese made products. Granted, I have used some AA lithiums for years with no problem of them leaking either.
My experience are the exact opposite. Duracell, Energizer, etc. all leak, the "off brand" ones like GP, Varta, etc. that come packaged with new battery operated devices are much less likely to do so.
I don't buy any alkalines anymore as I have had such bad experiences with them over so many years. NiMH or Energizer Lithium in everything.
desert.snake
Eastern Europe
Daewoo AAA heavy duty leaked inside the flashlight, I managed to pull it out in time. I looked at the second unused package and 1 of the 4 batteries showed signs of leaking. Made in China 03.2023. It's unlikely that the flashlight is the problem, it eats about 30 mA
Oh, I was wrong, they are saline, not alkaline
PhotonWrangler
In a handbasket
Today I grabbed my old LED tester out of my tool kit to test some LEDs. Pushed the button and... nothing. Dead battery.
I haven't used this device in ages so I was pretty worried about the possible carnage I would see when I popped off the battery cover. When I opened it up, there was a Duracell 9v with a manufacturing date of 2011 with NO leaks! I was astonished.
Looking at the battery closely, I see where the bottom is bulging a little bit but the battery's case is still completely intact. This battery says it was made in the U.S.
Was I just lucky in this case or was the U.S. battery plant doing something better back in 2011?
IMA SOL MAN
The HEART of the USA.
It has been my experience that 9volt bats seldom leak, but YMMV.
PhotonWrangler
In a handbasket
Thanks guys. When I think about it, you're both right. It's usually individual cells, not batteries (which are strings of internal cells by definition) that leak. I might open up this battery just to see what condition the cells are in.
**Edit**
I opened it up and found only a tiny amount of leakage from one of the AAAA cells inside. It was completely contained within the plastic wrap around the cell bundle, and the top and bottom of the bundle was sealed with a brownish putty. I'm impressed with the integrity of the internal seals.
Toulouse42
Jersey
Generally fine unless you leave one in a child's toy for almost 30 years. When we got the toy out for our grandson, the insides were well and truly dissolved.
Got Lumens?
Champlain Valley
Not all 9V cells are created equally.
There are some that use 6 AAAA Alkaline's and others use 6 AAAA Zinc powered series cells, and others
that use primary lithium cells.
Check the compatible ANSI number on the 9V battery to cross reference and find out if it is the case.
Regardless, 9V cells are some of the most non destructive failing cells that do and can leak.
There are now lithium based primary, and secondary rechargeable 9V cells available to purchase to negate
the leakage damage/syndrome.
GL
N8N
I think it was because it's a 9v. That's 6 small cells in a metal case. So the steel case prevented the caustic liquid from getting out. I've never seen a 9v destroy something
This, it's "double insulated" if you will. I still use NiMH 9v batteries simply because it's always seldom used equipment that uses them.
