ElectronGuru
Oops, last four posted. More already in production!
Got mine put together today, awesome bright! Thanks for the info on what's needed to run alternate batts, great info.
Yup, higher discharge cells will push more current into the emitter since there is no driver (and tail switch since most uses ZR) to limit the current draw.In this direct drive format, what difference does battery discharge rate make? The Eagletac 3400mah I'm running in this light is 4a-5a. The AW 3400 is 6.8a. I know these are the limits set by ICR. Would the AW give more output?
Mine arrieved last Week.Very nice peace of hardware.
I done a "quick and dirty" runtime test.
Here are my eye results with fresh out of the box Energizer Lithiums L91:
Total runtime to useful moonlight,i think 5 Lumens: 20h30min
The first 10h at ~200 Lumens no visible drop for me.
The next 6h it drops to around ~100 Lumens
The Last 4h30min the output falls from ~100 to ~5 Lumens.
I do the Test only with my eyes,no Sphere or other Technic Equiqment
U gotta need 2 x 1.5v cells to run a XM-L emitterWow. Is this with 1 or 2 of the L91s in the light?
There's an opposites thing with regulated vs DD lights. Regulation (see our triple) protects the battery from over discharge but the regulation itself can draw power to fast from smaller cells (risk to the cell). DD drops output to match smaller cells, preventing to fast a power draw, so the cell is fine. But DD has no protection from to large (to low resistance) a cell (risk to the LED). You can pretty much run any cell, with the following exceptions:
No IMR
One cell only (nothing over 4.5v)
Don't discharge farther than is safe for the chem of the cell
Dell thanks for your response. I have a few more questions for you or whomever wants to answer. I have both heads, xm-l2 and xp-l. So I decided , Hey! I'll measure the amperage output at the battery. The xp-l measured roughly 20% less. I used the same battery and even swapped the bodies ( c2/6p ). The problem is that I don't know how to use that info. I know just enough to get myself in trouble, as I've done here. Fully charged amps at tail cap: XP-L=3.2a; XM-L2=3.6a. With that, several questions arise. Is the difference in measurement between the two due to the emitters being different? In this Direct Drive format does amperage measurement at tail cap tell me anything about amperage going into the emitter and so on to roughly estimating lumen output? If so, and I'm using batteries that allow 6.8amps shouldn't my measurements be higher? I am obviously missing something because this light has "4.5+ amps to the LED", so I thought that using the recommended battery it would be 6.8amps. IN NO WAY AM I QUESTIONING ANYTHING ABOUT OVEREADY AND THEIR CLAIMS OR THE INTEGRITY OF THESE LIGHTS. I AM NOT QUESTIONING THESE LIGHTS PER SE, JUST TRYING TO LEARN ABOUT POWER, ETC. AND BEING DIRECT DRIVE A SIMPLER PLACE TO START!
