Re: vinhnguyen54 Modding/Repair Helpline ... Get your answers here!
P= power(watt), I= current (amp), V= voltage (volt)
P=IV
Say we have I= 3A, V= 3.7V, then we have P=11.1watt, An example would be the XML-T6 rated at 11W when receiving 3A of current
But
Say we want P=11watt (to acquire full brightness), V=1.5V (AA) what would the current I be?
11=I(1.5) -> 11/1.5=I= 7.33A
The simple example above shows how current reads higher with lower voltage.
Voltage= potential difference = the potential energy to move electrons ---> higher voltage creates a greater electrical/electron sparks. So increasing voltage result with an increase in power. But if you have less potential energy then the flow of the electrons simply have to increase to match similar power requirement. Our initial power requirement was 11watt to achieve full brightness. At least as claimed by CREE.
Most LEDs Vf voltage is 3.7V so 1.5V wont lit it anyhow. No matter how many 1.5V you put in parallel to increase current the LED still wont lit. I am assuming you set up the 4AA in 2S2P to acquire a voltage of 3 volt? In that case the nominal voltage of 3V AAs in series is still less than the nominal voltage of 3.7V so the current reading should read higher as you saw.
Am my making any sense? Sorry I don't know much about electrical so may be someone else could chime in or correct me if I am wrong...
P=IV
But
