Modding/Repair Helpline ... Get your answers here! :-)
djans1397
Bozeman, Montana
Re: vinhnguyen54 Modding/Repair Helpline ... Get your answers here! :)
I must have overlooked it then because I can find no such instruction. Just bits and pieces of what others have said. Could u give me a link to your instructions? I've read others say to be careful not to pull out any wires or touch the underlying LED. I'm sure its prob a simple task. I just want to do it correctly as I have no intentions of having to replace my LED.
Thanks much,
Dan
The instruction I gave above is pretty much it. Not much eles I can add. you will still have spill but its just a dimmer. The biggest change would be a neutral tint and a brighter hotspot. If you like cool white then don't mess with the dome. I would dedome if I was you because I love THROW! Too bad the tint shift to a less desirable tint though. Try it! if you dot like it then buy another LED. Its just $30.
Skylumen
Sorry I am being crazy! Post number 5
http://www.candlepowerforums.com/vb/showthread.php?334219-vinhnguyen54-Olight-SR90-amp-SR91-De-Dome
Thanks much,
Dan
djans1397
Bozeman, Montana
NM. I found the thread that explains it. I guess I was expecting something more complicated.
TEEJ
NJ
Air cool like a tiny fan would be easy to do. :)
I guess it would have to blow through external fins though, use heat pipes, etc...if it was to have good water resistance....
LOL
Maybe take the Olight MX6 form factor, but have a refrigerator/condenser/coil module on the belt instead of or in addition to, a battery.
:devil:
lightknot
Tucson, AZ USA
Anti-freeze / Anti-boil / liquid cooling in a handheld light.. It could be done! Something like a mega illuminator would have the case size to handle it.
(INTEL cooling kit) Wayne could do it . +1 for his lights / mods.
TEEJ
NJ
LOL
Now to scale it down for a pocket light.
:D
Skylumen
I am excited for the TN31!
TEEJ
NJ
Unless they severely understated the lux, I don't see how they will get 700 meters of throw though. (Unless I screwed up the math for 75,000 lux)
Even so, 500-600 meters is STILL pretty impressive if they can get it in that sized light.
:D
tobrien
Georgia Highway 441
How I stack 7135 Chips:
1) Clip off the middle leg as you don't need it
2) bend the outer legs to curve downward
3) Dip the two small legs and the rear leg into flux.
4) Add heated solder to the legs.
5) Add heated solder to the same three legs on the chip mounted on the board
6) Now stack them on top of each other and solder the large rear leg first. The solder should just melt in.
7) Solder the two front side legs. If the solder won't flow add a thin copper wire to create a solder flow path.
http://i912.photobucket.com/albums/ac323/vinhnguyen54/DSC04258.jpg[/IG]
[IMG]http://i912.photobucket.com/albums/ac323/vinhnguyen54/DSC04255.jpg[/IG]
[IMG]http://i912.photobucket.com/albums/ac323/vinhnguyen54/DSC04256.jpg[/IG][/QUOTE]
what does chip stacking for flashlight drivers do?
BudK
Southern New Jersey , USA
Each additional chip that is added is 380(?)mah of additional regulated current capacity to the driver .
Wayne , what is a good supplier of empty p-60 drop ins ? I want to experiment with different reflectors & whatnot .
Thanks .
Bud
doctor ladd
Massachusetts
I would like to know about removing chips from drivers.
What is the best or easiest way to do it?
Once the chip is off do you have to do anything else?
Skylumen
kaidomain in china or illuminationshupply in USA
Thanks .
Bud
Skylumen
To remove a bunch of chips at once use a heat gun. Use a solder iron for one at a time.
BlackhawkB
Hi vinhnguyen54,
I just saw your mod with your TK41, and I was thinking you could help me as well for my fenix.
Basically I have a Fenix TK21, that I use with a redilast 2800mh. This light is great, but the turbo mode seems to be low compared to some cheap lights. I think my 18650 redilast is not the issue, as it should be a good battery.
So I would like to mod this light, but I can't find the way to open it, everything seems to be glued in the head, I can't even differentiate the different parts.
I try to heat the head with a hair dryer, but it didnt work. I am scared to damage the HAIII if I heat it with something stronger.
Do you have any idea ?
After that I guess it will be another challenge to mod the fenix-specific driver
Skylumen
It is very very hard to damage the HAIII with heat. Just heat the crap out of it! I use a heat gun so it's much hotter than a Hair Dryer! Anyway. Heat it up and use blue garden rubber gloves to twist. You might even need a vise for very stubborn lights. let me know.
Hi vinhnguyen54,
pulstar
Slovenia
Hi Vin!
How about emitter swap in my Surefire Saint Minimus? Would you dare to try it?:) I have a few modding experiences (i replaced emitter in LX2 and L1), but minimus is entirely different beast:)
Skylumen
Hi Vin!
I dare try everything! Doesn't mean I can do it though :)
pulstar
Slovenia
Well, do you think you could do it?:)
Skylumen
Vinh Nguyen
9706 8th PL SW Unit 204
Seattle WA 98106
Send it to me. If I can't mod it I wont charge a penny.
