cdrake261
Alrighty, been a while since I've updated...The part of the main heatsink that slides into the body is roughly 26mm long and and the space between the top of the tube and the switch cut completely flat is also roughly 40mm, so that gives me 14mm to work with if I don't cut the main heatsink back(ideal for XM-L's heat management) or if I trim the heatsink back by 13.5mm(not ideal for XM-L's heat management) and I would then have 27.5mm to play with. So I am considering angling the driver, which throws the driver heat monitor and cut off features out of the picture, status LED may not even make it in the picture either...
The h6flex is a hair bigger then 33mm and the maglite tube is 34.16mm and originally I was going to lay the driver horizonal but that wouldn't give me enough room for my 18ga. wires(diameter of about 1.88mm). This driver is just plain too large for this maglite without fancy heatsinks to angle it.
Another option is to not use this driver and find a smaller 2 or 3 mode driver that will fit inside the heatsink ID of 26.5mm or smaller....any idea's?
Here's my thoughts on the driver heatsink if I decided to go with the TaskLED driver...
