Fireclaw18
- Joined
- Mar 16, 2011
- Messages
- 2,408
I just checked out the ZL website and learned that this light is less than a mere 2 mm longer and larger in diameter than the SC51. This doesn't seem like very much, yet you said it was "noticeably larger". Do you have both lights? I am becoming more intrigued by the SC80, thanks to your comments.
I am thinking that since it's hardly much larger (on paper), and that it has the bonus of running on different batteries, and that it does not have to be locked out, that maybe this is the light I should have purchased, and that it very well could be MY "perfect" light.
Does anyone know if it puts out the same beam (brightness, spill, throw, etc.) as the SC51, which I think is "perfect" for general purpose.
I had both lights (SC80 and SC51).
The SC80 is about the same size as a Sunwayman V11R. It's only a tiny bit larger than the SC51. About the same length, but slightly wider. It is however, noticeably heavier than the SC51. The SC80 has very thick battery tube sidewalls, plus the brass adapter insert adds extra weight.
The reflectors and beam patterns are identical on both lights. The pure white tint on my SC80 is better than the slightly greenish tint on the SC51.
