My little 10Watt HID MONSTER
Ra
The Netherlands
mst3k said:
So, how long from dream to completion on this bad boy??
Im guessin considerably under a year, right?
In fact its over a year! The design was already taking shape more than a year ago, but the hard part is finding a reflector accurate enough for this project.
The manufacturing of the little beast took about two months.
The reflector was the most difficult to make, its made out of very hard ceramic material. The ballast and lamp I grabbed out of a UK Light Canon 100. The 18650 cells from Ebay.
The best I can come up with to compare it to is a pistol-grip halogen torch I modified a few years ago: a 6volt 30watt projection bulb is overdriven at 7.2 volts. This torch puts out 225,000 beam CP (calibrated measurement.)
I'll make some beamshots if I can find the time today.
Laterrr.
Ra
The Netherlands
More Beamshots...
Later tonight I'll come up with beamshots taken in the field, but for now:
And...
Looks like one of the nebulae in space....doesn't it??
And for surface brightness:
Ra.
Mike Painter
Beautiful. The size and burn time make me drool. I'd like a rugged version that gave up on precision for strenght that I could carry with me as a volunteer firefighter/EMT.
A snap on for wide angle/closer work would make it perfect.
And while the black is beautiful a bright orange or yellow would make it easier to find if dropped on a job...
(And a $24.98 price tag while I dream...)
tonyd
Very impressive. You really have a great design talent. I'm sure a limited run of these lights would sell instantly. Great work:goodjob:
Ra
The Netherlands
Well Monkeyboy, it runs just over two hours on one charge.
And ...I din't know about the 2600 mAh cells... I'm going to order a few of them! Thanks for the tip.
Regards,
Ra
bombelman
This might get me into HID's....
What is the host, and was the switch a Mod, or Standard ?
Cheers !!
Ra
The Netherlands
Sorry bombelman..
There is no host, its my own design, with the help of a friend who machined most of the parts.
The switch is a combination of a reed-sensor and two relays. The relays need to cope with high peak currents at startup.
A little magnet embedded in the green ring triggers the reed-sensor from outside through the aluminium: Completely waterproof !!
The relays are not visible on the drawing, but they are located around the reflector.
Groet..
Ra.
windstrings
N Central Texas
Laterrr.
Looks like a class act.... whats the conversion to lumens of throw?
Ra
The Netherlands
Hi windstrings,
Nice of you to revive an old thread of mine..
I forgot a few beamshots I promised:
And:
I don't know exactly what you mean by "conversion to lumens of throw"..
The lumens output of both torches is almost the same. Only the much higher surface brightness of the HID makes it produce equal throw with a much smaller reflector !!
Happy new year windstrings..
Regards,
Ra.
DM51
Borg cube #51
I have only just seen this thread (thanks for reviving it, windstrings) and I REALLY, REALLY WANT THIS LIGHT. Being rated to 200ft / 60m, it would be a great dive-light.
Any chance, Ra??
Ra
The Netherlands
Any chance, Ra??
Sorry DM.. not at the moment !
With all the effort it takes to make this, it propably would cost close to $1000 !! And I simply don't have the time right now. And some of the ingredients are hard to come by !!
Beleve me, I had to dissapoint a lot of fellow-CPF-ers on this..
Regards.
Ra,
Ra
The Netherlands
Under water,, It looks nice too:
Its not 60 metres ofcource.. For that I would have to take a swim in the sea, brrrrr,, toooo colddddd d d d d.
Edit: If I would ever reach a depth of 60m.....
So you'll have to accept a depth of 10 cm for the time being...
Regards,
Ra.
JimmyM
Boston, MA, USA
Neg2LED said:
me likes! i wish i had the knowledge (and cash!) to make something like this....
--neg
It's really no big deal. You just need a lathe, possibly a milling machine, a lot of experience, access to an anodizer... See? simple (Raging sarcasm) !
I swear. It's complete, from a billet of aluminum, custom lights like this one that make me green with envy. I love this thread, Ra. Glad it got resurrected.
