milkyspit
Absolite, thanks for the compliment on my pimpin'. /ubbthreads/images/graemlins/wink.gif
Okay, let's see... it's the same reflector in both cases, so sidespill is identical in diameter, but throw with the Dorcy circuit is maybe 20% less than with stock. (That still leaves plenty of throw, though!) The main reason for the Dorcy circuit was twofold: it runs for at least TWICE as long as the stock circuit; and it fails far more gracefully. On the latter point, I did a runtime test on my MilkMite mod, which also uses the Dorcy circuit, and even after 8 HOURS of continuous runtime on a single 123 cell, there was enough light to navigate the rooms of my house and find things in drawers. Simply put, I just trust the Dorcy circuit far more than I do the stock circuit not to let me down when I need it. /ubbthreads/images/graemlins/grin.gif
Yes, the dual brightness switch could be installed in the stock OR pimped Q3, but you'll need to be comfortable soldering and unsoldering things on circuit boards. If not, you could always send it to me for modding... I'd probably only need the tailcap, not the entire light. The stock switch sits on a little circuit board in the tailcap, and basically you'd need to desolder and remove that one, then solder down the new one, and finally run a resistor from one of the outputs of the new switch to the output pad on the little circuit board.
I haven't received the switches yet, so it's a little premature to put a price on them... but I'm sure it'll be under $10 shipped! /ubbthreads/images/graemlins/grinser2.gif Okay, maybe that doesn't say much, but the point is it won't be a backbreaker for anyone. /ubbthreads/images/graemlins/smile.gif
