You seem to know a lot about "nothing".
You don't have any experience with the E1B. This light was practically made by cops for the cops. Why would you want a strobe on a tactical light? I'm pretty sure none of SF's torch's have strobes, and I'm glad that they don't. If press rapidly on the tailcap, you could use it as a strobe if thats what you really want. I've never had a problem going from high to low, or vice versa no matter what situation I'm under. From low mode you can go directly into high mode without waiting 2 seconds, and the same from low to high.
I'm not going to question the people who designed and engineered this light, all I can say is they did one hell of a job.
Steve
"Steve",
No need to get hostile with your accusations of know a lot about nothing, whatever that means.
First, I stated "manually strobe", which means rapidly hit the tailcap button (that's the "manually" part) to turn the light on-off-on-off-... to strobe the light. Manually strobe does not mean having a strobe mode. Thus, your first rant is simply off-base. Also, perhaps you might ask former Navy SEAL Ken Good why he designed a strobe in the Gladius tactical light as to why one might want a strobe mode. Please note, however, that my comments were not meant in any way to suggest that the E1B should have a strobe *mode*.
Of course you can go from low to high directly in less than 2 sec. That assumes that you *start* in low mode. Since the default mode is high, let's start from there. You now turn off the light. Suddenly, you need the light on again, and it has to be in high.
What are the options? If the time interval is less than 2 sec, how do you get to high directly again? As far as I can tell, you can't. You have to cycle through low mode first. Yes, if the time interval is longer than 2 sec, then you can access high mode again directly. But how do you know how much time has elapsed to be able to select the correct operational course of action? Who wants to have to keep track of the passage of 2 sec of time when doing a building search? Do you also count your rounds that you fire?
Ever do light on, shoot, light off/move, light on again, shoot, etc drills? Let's vary the time intervals between light on/off/on to anywhere from a fraction of a sec to several sec. You need to see, ID, and perhaps shoot a target right now. What mode is your light going to be in when you turn it on?
I'm glad that the E1B was "practically made by cops for the cops". But I'm not quite sure what that means, either. "Practically"? It either is or it isn't.
I have no problems if you do not want to question "the people who designed and engineered this light", but please don't take such offense when others do question the design. There is no law of physics that says that SureFire (or any other company) is always right.
