veering far offtopic.. sorry:
about escorts.. i could not ever get my leg comfortable on the gas pedal. there was no support for it. so i had to take off road every 150miles just to stretch my legs because of that alone. that on top of the crappy seats with short bench and no side support, and the wrong angle steering column.. did you notice that at all. (all i have driven had the steering wheel in slight angle, not aimed at the driver dead on. and many had the gear box also in angle. the gears didnt go straight foward and back but few degrees to right side) 1st gear was too short to be useful as it run out too fast, basically just to get the car rolling, and engines (1.3 and 1.4) were too powerless to use the second gear to start moving. i hated them all. (none of them were mine, but my grandad, my dad and my sister has had 4 of them that i drove alot too, best was my dads 1.6l ofcourse. not counting the 1.8 and hopped up versions with turbos my friends had) but like said.. hated the escorts as driving experience.. but except one particular car they all worked fine and did what a car needs to do. move, stop and turn.
there is always a need for little bit of more power, but that can can somwhow compensated by smart driving by the perseon behind the wheel. to see into the future. know that your cars acceleration is like molasses mixed with bungee cord you learn to prepare to it. you dont try to make it into tight spots at all if you are not used to be able to go there. jumping from powerful car into no-go version will be difficult. one gets used to the performance.
i have been actually waiting for the manufacturers to start installing NOS systems into the small cars for that small short need for more power (overtaking or something like that), thats what they are doing with hybrids (when one needs more power both engines run), they have tried that with "overboost" functions in turbo cars (few seconds of more power available, not available for all the time but just for while). or some aftermarket company starts promoting 10-20hp nos boost for econoboxes alone.. dealer installed and factory warranty stays kind of deal. economy when one needs it, instant boost of power for seconds if you really need it, and then back to the shop to refill the bottle when needed. (easy revenue to the dealer, refilling the bottles.)
this might be viable solution to power needs vs economy, because seriously if one knows how to participate the need of power and learn to drive with slow car they dont need the extra power that often. i would imagine hardly anyone really drives their cars daily so that they are always at peak power when shifting. (those that do, they drive too agressively and they often already have a powerful car in their use.. most commuters dont ever see more than 3000rpm if they drive normally and smoothly, i know i dont) and this way a 20hp for 10seconds boost from nitrous oxide bottle would last a long time. if i recall right, 10lbs bottle of nos, lasts about 7-9 times of 100hp shot before running low.. so that would likely make it roughly 35-40 of 20hp shots available to eco friendly motor. plus with these new fancy computer injection electric computer-stuff the engine should be easy to compensate for the nos blast so it wont detonate etc when you press the boost buttons in the steering wheel. (yeah 2 hands operation needed so you do it intentionally and have a good hold of the steering wheel when you will experience the power pull! hahah.)
on topic.. ermmm.. lower mileage. dont go looking for a deal for low gas price.. likely you will burn the "winnings of few cents" while driving to find the station. if you KNOW some place sells fuel for less.. think if you need to go near there for other business or is it cheaper to use the nearest station after all. minimize the extra driving.
and again.. ooofff tooopic..
about diesels, i have learned that diesel injector cleaners (like LiquiMoly diesel purge) they are basically just kerosene. (the kind we use in storm lanterns etc over here) - i add a drop of 2stroke engine oil for safety measure to my kerosene treatment (3parts kerosene 1 part diesel) if i connect the bottle directly into the diesel pump end.. it will likely work without the diesel part but i like to play safer.
and i think gas engine injector cleaners have kerosene, turpentine(of sorts) and bit of octane booster.
and many oil purge/passage cleaners are also kerosene based.
