Their 90%-95% efficiency claim is suspicious. Sounds too good to be true.
Its is to good to be true. :mecry:
But 83,5% is good enough for me
I have measured the thing and I have to say I like it.
Unlike I have read somewhere else these drivers do have a memory function.
They will start working from 4,7Volts, they will stop working at 4,0Volts than the driver goes into a verry verry low mode (3mA to the led).
I did'nt see any flickering
Well here are the measurements in a excel file.
All measurements where made with calibrated meters.
Greetz Johan
How does the memory function work? In the drivers I got it just progresses to the next level every time you turn it on. Turn it off on low and it's on high the next time you turn it on.
Stefan
Good work SUBjohan. If you don't mind I've made graphs from your data.
Just turn it off in a mode, wait a bit and turn it on again and then its in the same mode as before.
Perhaps there is a difference in drivers, because my driver also came with a sort of rubber protection thingy for the coil wich is not seen on the KD pictures.
Greetz Johan
Incredible! They have different versions in the first batch. I have no form of memory in the ones I received. Turn it off on high, wait, it turns on in the low level next time it's turned on! And they had the rubber protection sponge.
Perhaps Kai could give a anwser to this problem ?
In my experience, when buying cheap, "made in China" stuff, two units of the very same item produced in China will, many times, have similar, but somewhat different components. That the supposedly same driver, received by two different people, works differently should not come as a total surprise.
My suspicion is that you will not get a clear, understandable answer on this one, if any.
Hi SUBjohan,
Your excel file is a very good job!
I like precise measurements, in German I say "WER MIT MIST MISST, MISST MIST." It's a pity that in translation the play on words gets lost.
How do you measure currents? My new AC/DC current clamp (Chauvin Arnoux K1) has a span from 1mA to 4500mA and very small jaws.
Wulf
I used 4 GossenMetrawatt Metrahit 29S multimeters so could measure everything in the same time.
Add to that, I'm disappointed the medium isn't more logarithmically placed between the other two, but that wouldn't suit everyone either. It would be nice to be able to set them wherever.... the poor efficiency on med and low looks like they use a improper way to dim, ...
So i've been reading the replys and it seem to be a positive towards these driver's but they are not very efficent on med and low ? in the real word does this shorten run time by converting power into heat ? how does it hold up against other drivers ? cheers DocD
