Just a quick update. I'm starting a run of the 123 version and the AA version. The 4AA version is delayed due to a board screw up on my part and I need to re-order the raw boards.
Here's a picture of the two side by side.
I will be making these available in April time frame.
Tentative pricing will be:
1 for $85.00 ea
2 for $75.00 ea
3+ $65.00 ea
This price includes NRE and is not indicative of the product cost + labor to assemble it.
Disclaimer: While I make the best attempt at glueing and assembly I'm not absolutely perfect. There could be minor cosmetic blemishes, slight mis-alignments of objects.
Final color for the top may not be what is presented above. I do not plan on offering different colors at the moment and that will change over time as I figure out how to make the product SKU with colors on the shoppe and take care of the logistical nature of stock and inventory.
The price is for either unit. You could buy two one 4AA version and one 3X123 version for the two piece pricing.
I will be offering the 123 sooner than the 4AA. If you want a mix of AA and 123 then you should wait till both products are available.
if you only want the 123 version then you buy sooner.
Looking at the picture the 123 configuration as shown in the picture counting from left to right battery 1, battery 2, battery 3.
You only need to load Battery 1 and battery 3. The center one is not needed and the two outter batteries are there for weight stability.
For the 4AA counting again from left to right 1, 2, 3, 4. You only need to load 1,2,3 for a minimum configuration. Four AA cells is just as good as three cells.
Hope this makes sense.
-Wayne
