New QTC pills?
ElectronGuru
Oregon
Are you out of stock with the HiCRI logan heads? I could swear you had HiCRI heads in stock a day ago. Is the warm tint option same as HiCRI?
Yes and yes. Nichia neutral and Cree warm are both high CRI.
Nichia heads are proving difficult to keep available. A larger batch is in production.
Also curious about large/optic. Is this equivalent to a medium or narrow optic?
All OR optics are narrow. These are diameter descriptors:
large logan - standard
large eiger - ultra (same as logan)
small eiger - standard​
I'll take pictures of the options when the flood heads are ready.
De-Lux
Maui, Hawaii
Thanks for your time. Much appreciated. Are you going to have flood heads with the Nichia neutral High CRI? If so, when is the ETA? I was also curious if you are expecting any of the Moddo clips for the logan any time soon. Thanks again.
De-Lux
Maui, Hawaii
ElectronGuru,
Would it be possible to pre-order a high cri Logan with the new nichia 219? I would prefer one with a floodier beam if possible. I would be more than happy to pay in advanced. Thanks again.
ElectronGuru
Oregon
Tom is working on more clips as we speak, but I have no basis for an ETA.
Yes, but flood heads are still in development, with no ETA.
The 3rd shipment of Nichia heads is due in the next 48 hours. They're all clear/narrow optics, with enough of both logan and eiger sizes to 'populate' every page/model.
elugelab
Helsinki
ElectronGuru: Could it be possible for you to get the Peak Eiger Ultras (in brass or SS) with the Nichia 219?
De-Lux
Maui, Hawaii
ElectronGuru,
Thank you for your time. I am going to hold out for the floodier heads. I will keep checking the OR site for their arrival.
ElectronGuru
Oregon
Yes, but new Ultra development is seeing delays similar to the flood heads.
Do we send in complete lights, the head and body, or just the body?
Send only the body, unless you have a unique configuration you think the factory should consider when doing the upgrades.
De-Lux
Maui, Hawaii
ElectronGuru,
whom am I kidding. I don't have the patients or the self control to wait for the floodier heads. I will thow a little diffuser film over the lens to get a floodier beam.
I do have one last question in regards to the QTC pill. Do you find that the QTC works better or worse with the momentary switch? Thanks again for your time.
ElectronGuru
Oregon
I would say about the same - neither. During final assembly, I test each setup like so:
  1. install qtc
  2. lube threads, install head
  3. remove head, wipe
  4. install battery, install head
  5. check for twist low/high, low recovery
  6. check for momentary low/high, low recovery
  7. check for twist low, momentary high, low recovery
  8. remove head/battery, wipe
  9. assemble
  10. clean
Step 7 here is a key feature of this setup, making sure the switch will take the low 'setting' up to medium-high, then return back to low when released. The switch doesn't affect the way the head presses on the pill, it simply adds an extra option for doing so.
GrimCreaper
Tucson, Az
When we do the upgrade option, do we send in the body + head or just the body?
Would it be possible for peak to correct the issue with the TIR in my warm white light as well? Theres a rather large bubble on one side that makes a very visible mark in the beam. the only novelty to it is that it makes it look almost like an older standard bulb (non led) flashlight with an off center bulb.
De-Lux
Maui, Hawaii
ElectronGuru,
Thanks for the response. Seems to me that using the rotory switch from the first responder series and installing it into the back portion of the battery tube of a Logan would be a more ideal and reliable setup for variable output. Much like an hds rotory. The down fall would be added cost and length. Have you considered this modification? Thanks for your time.
elugelab
Helsinki
ElectronGuru: Thanks for the answer. Got one more question... Could you get some of the other Eigers in brass?
PoliceScannerMan
Gainesville,FL
Two posts up. ;)
I believe you are reffering to the part where the optics are molded when made. I'm afraid nothing can be done about that...
De-Lux
Maui, Hawaii
Throw some diffusion film over the lens. Here is a thread for purchasing diffusion film. This stuff works miracles for flawed beams.
ElectronGuru
Oregon
I have many ideas/requests in with Peak, but they are a small shop and can only do a few major things at a time. Once the flood and ultra and special metals are flowing, we'll look at additional refinements.
We're looking at additional metals. Just need to let Peak dig out from other projects.
+1
The smoothest focused beam is produced by textured reflectors. The smoothest even beams are achievable with no reflector or optic. The point of going with an optic is to get the most possible throw in the smallest possible package. The price for this is beam quality. Assuming you are describing the manufacturing artifact and not some random damage, it is present along the edge of every narrow Logan optic. A similar mark is visible along the edge of every M60 optic, seen here at 2'oclock:
dy5
College Park, MD
Just got my Peak bodies back with their new QTC pills. Took about a week. The improvement is dramatic.
David
