I have received my X40 today, serial Nr 34 and I had a little play with it tonight. The UI is brilliant - really infinite steps. The control ring has just the right friction, so that I can move it with one hand.
The beam pattern is a good compromise between spill and throw for my taste and the multi emitters give it a nice flower shape, what is important too
The charging port cut out reliably on fully charged batteries and the manufacturer assured me via email that there is no way to short it out. I did top my cells up in a charger just to make sure they are even, but parallel charging is another feature to be mentioned. I will get a multimeter out and examine the battery holder to see how far that is true. It has one connector for the head on on side and 3 springs on the other for the parallel charging.
The temperature regulation is visible so after a few minutes on maximum with no cooling and 30C˚ it steps the brightness up and down a tad until it decides to run on a lower setting, but it's just noticable, not annoying.
I could have done without the strobe mode, but that's just personal preference, as I don't the need for a random strobe at all, if at all I would like an SOS one. It comes after Max, but there is a solid click between 3LM / Min and Max / Strobe at each end of the range, so you can know where you are at any time before switching it on. Very well done.
I have nothing else that big to compare it too, but I can say this is an excellent product and the company was superb to deal with.
