nanotech17
WT@#$%!
that is bright!
very nice.
one more question - is this direct drive?
that is bright!
very nice.
Thanks for sharing!!
How did you solder the cells end to end like that?
How do you "aim" the emitters... is it very sensitive to how on-axis they are?
Nice work
Can anyone advice me whether it is safe to run all the Crees @2A with my setup? i am using Multisink from download and all three(oops! edit:five) emitters are using thermal compound and pressed hard by the windows..it is hot already with current setup but i was thinking of bumping it up a bit....
Thanks.
Personally i would add 0,22R resistor to each led...rizky_p,
do you think it is safe to run 2x 18650 cell in series to direct drive 5 crees without any resistor?
anybody would like to chime in?
It is buck driver, you could use it if you have had 5-6 li-ons in series.Thanks.
How about this driver - http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=2982
Thanks.
Rizky,
What Cree stars are they or where did you get them? What did you use to cut them down and is there anything to be concerned about in doing so?
Do you think if you trimmed a little off the outside diameter of all the reflectors or trimmed the threads at least, they you could have fit them all without them touching?
I'm on the fence to order the smooth or orange peel ones. I like throw but wonder if there will be a ton of artifacts with 5x smooth reflectors hehe.
