yaesumofo
Sounds like a job for the surefire 6P or g2 and a Malkoff drop in.
Good thing you canceled that deal extreme order. it may have taken a long time to get to you.
The only down side to the Malkoff is that they will only work for about 90 minutes before requiring a battery replacement.
The upside is every one of your other requirements are fulfilled.
The fact is that Surefire builds a top grade USA made flashlight which will not fail you in your moment of need. They are in use with armed forces, police, fire, and medic units world wide.
The total cost of a 6P and a Malkoff drop in is about $115.00 You may even be able to get a special military discount if you ask.
I personally own this setup and have no problem recommending it for extreme use.
The Fenix T1 is another light which comes highly recommended. it is extremely Heavy duty there was a stress test done on one in which a light was abused beyond anything that would be considered reasonable and the light still functioned.
This is a very bright light.
it is Chinese made and sells for $70 +-.
Both of these lights run on 123a cells
Rechargeable batteries are available but I do not recommend them for your particular use. if a battery dies in the field you do not want to be worried about the battery's. toss and reload.
If there is a question about if these will be available in the field bring your own. they cost 1 each.
keep your head down
Yaesumofo
keep your head down
Yaesumofo
