Igor Porto
Return to the store or trim down a bit of the piston length?
Return to the store or trim down a bit of the tube length?
I am having the same problems with my new (yesterday) EX10. With the head partially unscrewed, momentary works, and the piston moves freely. With the head screwed down, even with no battery in it, the piston is almost locked in place. Will hardly move at all. When the head is screwed down, it will either be continuously on high, or not lit at all. The switch does nothing. If I partially unscrew the head it flickers or turns on/off by itself, and does all manner of strange things. It just doesn't work until the head is unscrewed enough to use momentary.
I cleaned the body and piston very well, it moves very smoothly with the head screwed out for momentary. With the head screwed down the piston seems "trapped" and unable to move.
I feel the same. My solution was to buy some electric shears and do it myself. It saves a fortune if you don't mind being a baldy! :laughing:
How well does the battery sit in the tube? The battery should protrude from the tube a little bit but be fairly easy to press down into the tube roughly 3/16 to 1/4 inch or so (just guessing).
I an thinking that the spring inside is binding and not letting the battery recess back inside the tube far enough for the light to work when the head is tightened down. My button was a bear to push so I nipped about a half turn off the tail and restretched the curl back out so it would fit snug in the piston again.
Also, what snowlover91 says is true as well. IIRC 7777's posted about it a while back. I think that is usually the culprit.
I love my D10. I still think it is one of the greatest advancements in personal lights ever.
Don't know about the op, but I haven't gotten mine straightened out yet. I'm trying each of your suggestions one by one. Thanks for the help!
I don't know what happened with the OP, but I sent mine back to 4sevens today. Gonna exchange it for a 2nd P2D Q5.
Me too, in fact I love my D10 so much I am wanting another one T
Hi guys. Here comes my first post
I just recieved a Nitecore D10 and Im having some problems with it.
Was told to contact you guys.
The problem Im having is that after putting the battery in and screwing it together the light goes on but I cant even get the tall cap to move. It like rock solid... And if I unscrew it a bit I get momentary on but can seem to find a position where I can click on and off.
I dont want to start messing with it if there is a easier solution.
Please help a noob
I don't know if its the same problem, but when trying to press the piston on my D10 it was stiff and didn't move smoothly.
I changed the o-ring and re-lubed, also turned the brass contact ring in the head. It still did the same thing. What I then did was to loosen the head just a little bit, not enough to make the switch momentary, that solved the problem. It now moves nice and smooth.
They seem to have cut the threads just a little bit too far, cramping the piston when screwed up fully.
Another reason for needing to loosen the head could be the battery you are using is a bit too long. This is particularly true with some of the rechargables, other than the AW brand which seems to work ok without unscrewing the head.
