I have one of these in the tan finish, and was really enjoying the light. I found it to be a nice combination of flood and throw. However, the gasket I received is defective, and the light failed a water submersion test in my sink. I don't know if the head is supposed to be sealed, but the reflectors are filled with water. The entire head is filled with water, and yes, I had the plug cover properly in place. I believe part of the problem is that the gasket came without lubrication. That means it was screwed on at the factory, and screwed off by me, dry. I think the gasket got pinched. The defect is visible. Anyhow, I hope the vendor will be cool and work with me on this. I'd actually like to get the same light. I'll just be aware of this in the future, and visually check the gasket when I get the replacement. So make sure you lubricate the gasket when you put the batteries in because the light arrives dry.
I also found the light to get pretty hot when using the highest setting for more than a few minutes, but I had no problems with ring seizure, play in the handle, or battery rattling.
