They downgraded from 5500 to 5233 lumens or you just called it by the spec?
Then I don't understand why SOS and BEACON are not programmed in max outpu mode, where all other flahslights uses it in this mode, for a simply reason: SOS mode at least is an emergency modality and the flashlight have to use it in the maximum outpu available because you have to be reached and viewed from a long distance. Reflector and LEDs are not able to illuminate in a long throw, but this can be enphatized if the output of these modalities is maximized.
There would not be temperature problems, and if in the case they still be, wouldn't be problems, because the sensor would step the mode down. What do you think?
Other changes seems to be good.
