45/70
NiMH wont work the voltage is too low to not use alkalines, till now, but will it be too much power?
A bit OT, but I've never come across a portable heating device like you describe, that was voltage dependent. These devices are purely current driven, and good NiMH/NiCd cells always work better than alkalines, because of this.
I suspect that the NiMH cells you are trying to use, are suffering from voltage depression (which means they can't deliver significant current, as well, except at very low rates) and just can't deliver enough power to create any heat.
Go ahead with your NiZN trial, but NiMH's should blow away alkalines in this type of device, if they are in good shape. You have to be careful not to over discharge NiMH cells in something like this, especially when they're in series, or you'll kill the cells. Recharge, well before they quit working.
In my experience with "D" cell socks, I used 4500mAh NiCd's, and they were much warmer. They didn't last as long as alkalines, but they actually put out some heat.
Dave
EDIT: Awww, Mr H.
