RocketTomato
- Joined
- Jul 20, 2008
- Messages
- 475
... The Faraday cage relies on an isolated conductive "shell" to work properly. As someone above said, if you allow something conductive to make contact with the cage... It would actually act as more of an antenna then a protective cage.
The electrical field will always be zero inside a metal shell. No need to insulate.
You also want to ground it to dissipate any electrical charge that may build up but it is not necessary for it to act as a Faraday cage.
