Re: Object/Subject Review: Sunwayman T20CS (In Progress)
You're welcome :thumbsup:
I'll elaborate on my opinion as I finish the review, but basically, while I think the UI isn't as simple as I would like, it works well as a tactical interface.
The only 18650 cells I have right now are the Trustfire Flames 2400 mAh from DX. For the price I paid for them, I am very happy I would love to have some higher quality cells that could perform better in high output lights like this, but that's just not in the budget right now. If you can afford it, I would recommend something better quality, but if not, these will get the job done.
I've not noticed any flickering with any cells, or any other problems with the performance. I just believe that highe quality batteries will be able to sustain higher outputs for longer periods of time. I've seen a little info on Callieskustoms cells, I need to check out the pricing on those.
Thanks for sharing your knowledge of batteries! As far as I know, all the facts you've shared are true. On the higher modes, there will be more voltage sag (and I have definitely observed that in my tests, the voltage measured across the battery rises quickly after I turn off the light), and on the lower modes, there will be less. However, I'm not prepared to agree with your final assertion until I've looked into the specifics a little more. Your example makes sense, but the actual numbers are what's important, so we can't afford to guess. I'll do some research. What I need to find out is: the voltage it is "safe" to discharge a li-ion cell to, the voltage that is "healthy" for the cell to discharge to, and just how much the current sags on the lower modes.
Here's why. The voltage sag acts as a buffer for the protection circuit. The low voltage indicator on the T20CS sees the same sagged voltage as the protection circuit sees, so the "real" (resting) voltage of the cell will always be at least slightly higher than the voltage under load, and slightly higher than what the protection circuit and low voltage indicator see. This means that as long as the protection circuit is set to cutoff at a high enough voltage (greater than the healthy discharge voltage for the cell) then there won't be any problems.
For example, if it is safe to discharge a cell to 2.75 volts, and the protection kicks in at 2.8 under load, the resting voltage will actually be higher than 2.8, which is also higher than 2.75.
And anyway, if it isn't safe to run a cell down to the voltage where the protection kicks in, even under very small loads with little voltage sag, then that seems to me to be a problem with the voltage the protection circuit is set to, not the low voltage indicator on the T20CS.
I'll look into it more, but according to this page: http://www.candlepowerforums.com/vb/showthread.php?308451, it looks like for many brands of cells, there is still a small amount of usable capacity below 3V, which is about where I measure the T20CS's low voltage indicator to come on when in low mode.
Thank you, Bigmac_79, for the video on the interface. It clears up my confusion. Though, the interface looks busy, but I haven't tried it out myself yet so I can't make any judgement.
great review ! reminds me of a surefire Z2 on steriods, nice ! do you only have trustfire 18650, i need some not sure what to buy, are you happy with there performance in a high output light like this ?
Great reviews BigMac.
On a V10R or V20C XM-L's, the amperage is low; around 1.5 amps or even less.
On this T20CS with 658 lumens, the amperage is high; or close to 3 amps.
The electronic circuit will add to the amperage too.
Do you notice any flickering, or your Trustfires and XxxFires playing up?
Coz it played up on my SC600 with 750 lumens OTF.
Do you have any reputable AW or Redilast 2900/3100 mAH batteries to test? Because they may give you greater output too.
Callieskustoms are also high quality Panasonic cells, with aftermarket protection circuits added, but at a cheaper price than the others...
On the matter of batteries:
