nailbender
Re: P60 modules -warm, neutral, cool white/XRE-XPE-XPG-S2-XML-U2 / P60 modules (part
HI
OK Will Quiles has made some Very Low Voltage Drivers, these are for draining every last drop of voltage from old alkaline or NIMH batts. They will work up to 3 volts so you can use a 1XCR123 primary. You can read about it in his thread HERE at Will's Joule Thief thread , I have had many requests for so called vampire modules that would do just this run for long periods of time and drain every drop of juice left in the batts. Now these are not super duper bright lights but are certainly bright enough to walk around with and use in many other tasks. They make good emergency lights and everyone has old remote batts and toy batts.
I have tested these with a 3C daylight white XPG and a 3C XML and what I have found is that the XPG and XML are about the same brightness when running with a new 1XCR123 primary, the XPG will have a slightly better hotspot and the XML slightly more floody but basically the same brightness. I would say at 3 volts the brightness is slightly brighter than the LOW level on one of my stock XPG modules.
I also tested at 1.5 volts and the XPG was brighter than the XML but both could be used in a emergency lighting situation. I believe the reason the XPG is brighter is that the VF of the XPG is lower.
The way Will and I are working this at this time is if you want me to build your module go to his thread and buy the driver from him and have him send the drivers to me. The cost for me to build is the posted price on this thread for the emitter you want. If you choose a XPG then it will be $35 as posted, I am including potting for no upcharge on these modules. If you choose a XMl then it will be the standard $40. Shipping is included in the US as always.
As for emitters about any of the Cree emitters will work but if you looking for long lasting I think you will find that the lower VF emitters such as XPG or XPE will be brighter longer. This can be any of the tints that I stock and you can also use colors such as red .
Below are a couple of pictures of how I install the driver and how it will look finished once in place. You will not be able to tell a difference from a standard module.
First I seat the driver in AA to attach to the brass pill as below.
The wires protruding through the top will be connected to the led's MCPCB and the wires protruding out the bottom of the pill
and the cavity will be filled with thermal epoxy and battery contact board is put in place. Once in place the spring and grounding solder is installed.
This leaves a module that looks like the pict below.
Below is a beam shot of the XPG using a new primary at about 5 feet.
As you can see it is fairly bright for a single primary.
Thanks
Dave
HI
Thanks
Dave
