nailbender
I've been playing with the modules pretty much all day, and the strangest thing just happened. I had taken out my XM-L2 module to play with the XP-G2 for a while (had the XM-L2 one in almost all day), but now I just popped the XM-L2 back in.
Weird thing is, now it has 4 modes. All today it would only cycle 3 modes, now it has 4 (which is what it is supposed to have). And when I first turned it on, it was flicking like crazy in the high mode (almost had a strobe like effect to it it was flickering so badly). And for a little while it kept flickering in high mode, but now it has stopped again.
I think I am going to have to sent it back, as I don't think it's the host as the XP-G2 didn't have any of these symptoms, and both modules I didn't modify at all except wrapping them with the copper tape (they are being swapped in the Solarforce L2N host I got from you).
Yeah, something is wrong for sure. As I was writing this I went out to my backyard to go check on something, had the light in the second to highest mode and it kept going into the turbo mode and then back to the high mode along with plenty of flickering. Now I no longer have a moonlight mode, just low-med-high again.
Let me know what I need to do to get this back to you. And I was also wondering once you get it, could you install a smooth reflector on it? Or would that be an extra charge? Cause I'm thinking this might look even better with a little throw
Thanks Dave!
Hi
Make sure you have a fully charged battery when testing these modules, the moonlight will be flakey and it will pulse on high and med when battery is low.
Send back to the address on the package it came in or PM me for address, and make sure your address and what the problem is included in the package.
There is a charge for changing reflectors but only a small charge since hopefully you did not think I could use your OP on another module. If it is not new it goes in the trash.
Again make sure the battery is charged as there are very few bad drivers and all do get tested. I will be glad to test it see if there is a problem.
Dave
