Hello Dave,
Is it possible to get a Nichia 219b 4500K with 3 level L-M-H without memory?
Hi
I am sorry but I don't have any drivers like that, for one thing I am sure you do Not mean no memory since that means it would advance one level each time sooo that means you want a specific level memorized. We had a few that had memorized highs (always came on in high) and guess what everyone wanted ones that came on in low that year so we for now only carry last mode memory drivers. May look into it but not in the near future.
Sorry
Dave
Yes sorry, I meant always turning on in low mode.
Surprised there are not more people wanting this, maybe I'm strange
Dave,
Question, is it possible to make an LED module with TIR optic for XP-E²?
http://www.candlepowerforums.com/vb...-XRE-XPE-XPG-S2-XML-U2-NICHIA-92CRI-(part-10)
Hi Dave,
Do you offer the MC-E in either 5000k or 4750k?
Hi Dave,
I was wondering if you could build me a module that meets the following requirements? I've had a look on your website and didn't spot anything.
High CRI
Flood beam
Orange peel reflector
Around 500lm
3 modes - L M H
Runs off 2 RCR123A
Thanks,
Andy
Hi
Running anything anymore at 8.4 volts makes it tougher since most all leds run at well less than 3.5 volts usually. You can choose thishttp://customlites.com/P60-Cree-XPL-P60-XPL.htm
Choose the warm white 90cri and textured reflector and one level. At check out you get a chance to leave a note please note that you want a 1.5 amp high voltage driver. Using this driver will get you about as close as anything to 500 lumens might be a few lumens shy but not much. You could also use our standard 2.2 amp one level high voltage driver but it may be a bit over 500 lumens. The 90 cri is somewhat limiting to XML2 or XPL and your choice of 8.4 volts also is limiting either of those would come close one maybe a few lumens shy and one a few over.
The XML2 would also probably work but would have to be on the 2.2 amp driver to get close. Both are fairly floody if more is needed then try the solarforce convex lens as it is quite floody and smooth.
Dave
Hi Dave,Hi
Running anything anymore at 8.4 volts makes it tougher since most all leds run at well less than 3.5 volts usually. You can choose this http://customlites.com/P60-Cree-XPL-P60-XPL.htm
Dave
Hi Dave,
I have decided to use an 18650 or 17670 in place of the two RCRs. Do you still recommend the same unit, just without the high voltage driver?
Thanks,
Andy
Thanks Dave - order placed. Look forward to receiving it.Hi Andy
Here is what I would choose, http://customlites.com/P60-Cree-XPL-P60-XPL.htm Just put in notes 5 resistors (1.9 amps) and I will remember this conversation. Choose OP for reflector, and 3 level and choose the warmwhite 90+ and we will get you fixed up.
i think this emitter will give the most bang at the lowest amperage while giving the floodier beam.
Dave
