nailbender
Today, order placed an XP-L "Domeless" LED Module (CW).
Hi
Module shipped today
thanks
dave
Dave,
What is the deepest red emitter that you have ?
Thanks,
Mike
Hi Dave,
Do you offer a driver that has off-time memory instead of the standard on-time memory?
Hi Dave,
I have a SF 6P, how do you change between modes using that non-click tailcap? What is your current lead time or do you keep stock of the p60 modules?
Regards,
Clayton
Hi
As strintguy said the drivers work simply by cutting the power, other than cutting the power the switch has little to do with it. Our modules are last mode memory, once the light has been on for 3 seconds that level is stocked to memory. To change levels you simply cut the power faster than 3 seconds to change levels.
No we do not keep any inventory, we simply offer too many emitter choices to try to determine what to stock before a newer emitter comes out. We still usually have next day shipping, that said I am still in PT 2 a week but still we usually achieve next day shipping depending on build.
Dave
Thanks very much. I notice you don't post any outputs or am I missing something? What typically does your 4000k XPL Domeless put out with 2 x CR123? What would the run time be off those CR's? I'd like a flood that I can carry every day in a 6P.
HI
We long time ago quit posting outputs as everyone posts cree results which are not OTF, we carry the highest flux bins and push all at 3amp. Output would be 800 plus probably.
You mentioned wanting a floody light if that is so then you should go with the XPL as the XPL-hi is much more throwy.
If batts are 1400 mah then 3000ma divided into 1400mah would be a bit less than 30 minutes, levels will increase the runtime considerably if levels are chosen.
Dave
Thanks Dave, I edited my post while you were replying probably, how would the Nichia suit a flood EDC and what battery life could I expect?
Apologies for all the questions.
HI
Nichia is a wider beam angle but much less lumens, the nichia is only about 250 lumens if you choose the 4500k 90cri. If you choose the 219C 4000k we can probably get about 400+ lumens.
Runtime for the 45k 90cri is just under an hour on high as they are pushed at 1.5 amps. The 219C is pushed a bit harder so only about 45 mintues on high but again if you choose levels they will increase runtimes considerably when high is not needed.
dave
Order placed on your website for the 219C.
Hello,
I am considering a new dropin for my 6P host. My goal is throw. So am I correct in assuming that the XPL HI module with smooth reflector will achieve what I am after? 5000k tint will be my tint of choice so I know I'll sacrifice some lumens. Would another led/reflector choice offer better throw? Sorry for the newb question, been out of lights for a while and I'm just beginning to dangle my toes into the P60 realm. Thanks!
