Not bad at all! I am going to try some of the protected 2 for $10 ones next. The blue trustfires
After testing 3 of the UF reds with PCB I can honestly say, I'll never buy those again. At .5a discharge rate, the best I did was 1.7ah. These cells are a few years old but not used very much. I am now testing the blue TrustFires to see how they compare. These are 2500mah.
I was under the impression that the 3100 mah batteries were only for low current use and they will lose a lot of capacity when driven hard.
I am impressed that the Sanyos provided 2.4ah after the first charge and up to 5 amps draw. I am convinced that these are THE cells!!!
That is abosolutely correct for a single XML or soemthing similar being run with 2 18650. However, I was trying to find the best-ish battery for the 8XML video light and those are can pull 6 amps depending on battery/LED configuration so I wanted something better.... I am running the XMLs 4S2P and the batteries 6S3P. I think for the extra $1 the Sanyos beat pretty much anything out there. So from now on, I'll be using those.
Not arguing against your logic. I just haven't used Panasonics! I'll have to put them to the test. I am just impressed at running a cell at 5 amps and getting the same ah as I got at 1 amp!
Say Sanyos are 2 for $11 that's .0022 cents per mah
Panasonics are 2 for $18 kaidomain- that's .0029 cents per mah (that is if you truly get 3100 mah... chances are a couple of hundred short)
So the price difference may be justifiable as long as the application is right and the Panasonics fit the discharge rate requirement and if you truly get 3100 mah.
Next the Blue 2400mah TrustFires... At 1 amp, tested at 2000mah... At 2 amps 1800mah.
Moral of the story, buy name brand batteries! Skip the China crap...
The last ones I am going to test will be the unprotected green ones sold by DX. Those have been consistent in capacity for me, although still overrated.
