karlthev
Well...I just might get twisted into that...:thinking:...............:twothumbs
Karl
Karl
lol.....yes you sure do, just like I need another. If the converted price is correct it would make a nice 35W, 90 minute run, compliment to the PH50. On the down side, it takes a different battery but if we want a shorter light than the P series, I don't seen any way around the battery format.
In some ways, the X1 and Abyss are almost a better package design since both lights depend on handles. The PH style only had to be longer and skinnier to accommodate the handle-less PF style. Since there is no handle-less X1 they were able to make it fatter and shorter.
So what do you think Karl, "groupbuy!" :naughty:
You know I will be in for a groupbuy on this too. :naughty:
I sort of figured, but you know, it is going to want a big brother to mentor it. That can't happen if you sell your PH50.
I also note that this file identifies a run time of 20-30 minutes before it turns off (for heat management) when the light is used "on land". Used in the intended environment, the light would have sufficient cooling to run until the battery is exhausted.
Karl
"Because the Polarion AbyssTM is designed for underwater use, prolonged use on land can cause overheating. When this occurs , it simply triggers the thermal protection circuit and will shut down. It will return to normal operation once the light has cooled down."
Ok, I see now that it was under the trouble shooting section and the portion that I changed to bold was an example of a symptom. In that case I'm not sure why they assigned a 20-30 minute value since if the ambient temperature were lower it could just as well reach thermal shut down at 40-50 or 60-70 minutes. It seems to me that it should instead read. while using the light on land, it turns off prior to the battery being exhausted.While using the light on land, it turns off after 20~30 mins.
Because the Polarion Abyss is designed for underwater use, prolonged use on
land can cause overheating. When this occurs, it simply triggers the thermal
Well, you're welcome....if I deserve it...:shrug:
We're all Polarion fans here and I think we all want to get the best information possible before we pull the trigger on a buy. I'd like to see some response from others as well....Ken?? Are we reading the literature correctly?
Karl
