Jimmy,
Since I hope to be first in line for these, I will take a shot at specs for mine. If you need other info, let me know.
Got it.
But you don't need to specify Vbulb(max) or other percentages any more.
The voltages are set directly as voltage numbers out to tenths of a volt.
Also, disabling the overtemp shutdown is NOT an option. If the regulator exceeds 80C it could potentially be damaged.
In testing, the Vout was amazingly close to the programmed values. Usually < 0.01V deviation as Vbat was varied.
Mmmmm... 12-bit regulation.
Here are the settings I will use...
NEW X1 REGULATOR #1 for 64663 bulb
Level-1: 20.0V
Level-2: 27.0V
Level-3: 32.0V
Level-4: 39.0V
Level-5: 0.0V
Memory Start: YES
Soft Start: MED
Vlow: 40.0V
Vlow voltage based shutdown: YES
94%
Vlow timed shutdown: DISABLED
NEW X1 REGULATOR #2, and #3 for 4559 bulb
Level-1: 15.0V
Level-2: 20.0V
Level-3: 24.0V
Level-4: 29.5V
Level-5: 0.0V
Memory Start: YES
Soft Start: MED
Vlow: 37.0V
94%
