I ordered 4 of the 0180 parts last week, and I never had the chance to test them out. I tested 2 out of the 4 tonight and here are the measurements that I got:
Code:
LXK2-PWC4-0180
Current Voltage
(mA) (V) <Update:>
#1 #2 #3 #4
50 3.149 3.089 3.055 2.88
100 3.28 3.222 3.184 3.011
150 3.38 3.30 3.26 3.102
200 3.456 3.37 3.33 3.176
250 3.52 3.42 3.38 3.236
300 3.57 3.48 3.44 3.27
350 3.62 3.52 3.48 3.31
400 3.66 3.56 3.53 3.35
450 3.70 3.60 3.56 3.39
500 3.73 3.63 3.60 3.42
600 3.79 3.70 3.67 3.48
700 3.84 3.77 3.73 3.53
800 3.90 3.82 3.78 3.58
900 3.95 3.84 3.84 3.62
1000 3.99 3.89 3.88 3.66
1100 4.03 3.93 3.93 3.70
1200 4.09 3.96 3.97 3.73
In my test rig, I have a Fatman boost regulator powered from a battery pack. The Fatman has an external potentiometer attached so I can change the amount of current going to the emitter. The small sense resistor on the Fatman was used like a shunt resistor where I can measure the current with my volt meter by measuring the voltage drop.
So, I will try to get the voltages of the last two K2-0180 emitters and update this post later.
I am a little saddened by the high Vf of the new K2 emitters, but this isn't the end of the world. I have a certain application for all four, even if it means that a fraction of a watt more will be consumed compared to other emitters to produce the same amount light. If I needed a more efficient emitter, I would have grabbed a few of the older P4 XR-Es. Then again, the beam pattern of the lambertian emitter will work better than that of the XR-E. All that matters is that these emitters work, and they are still better than the old LuxIII and K2. Besides, I really like the tint of the batch of new K2s that I got. They are very white. Since the Rebel 0100 is so hard to find easily, these will do...
-Tony
<Update:
So, after too many days, I got around to testing the other two. Just a reminder, these are fresh from the cut reel packaging. Vf may drop, but maybe for just a select few of the K2 emitters and only a small fraction of a volt. Emitter #3 was used for more than 30 minutes over the last week in the test rig, and I found that the Vf did not drop one bit since the initial testing. Too bad.
I was rather amazed by the low (or maybe normal) Vf of emitter #4. At 1500mA, I measured a Vf of 3.83V (this is the only emitter out of the four so far that I went to 1500mA since I do not want to ruin my only test rig). This Vf is close to the Vf of the first K2 0180 emitter at 700mA!!! Wow! Good thing that these will be used in series in an application where heat and efficiency is not the most important. As I find anything more about these emitters from my testing, I will post somewhere in this thread. I ordered another K2 0180 with another Future order, so I may get some more variety of color and Vf due to the good 'ol "Luxeon Lottery".>
