I got my K2's form Future also. No bin codes on mine either. Something else I noticed though, product must be mounted within a certain period of time upon openning the bag. What!... Why?
LXK2-PWC4-0180
Current Voltage
(mA) (V) <Update:>
#1 #2 #3 #4
50 3.149 3.089 3.055 2.88
100 3.28 3.222 3.184 3.011
150 3.38 3.30 3.26 3.102
200 3.456 3.37 3.33 3.176
250 3.52 3.42 3.38 3.236
300 3.57 3.48 3.44 3.27
350 3.62 3.52 3.48 3.31
400 3.66 3.56 3.53 3.35
450 3.70 3.60 3.56 3.39
500 3.73 3.63 3.60 3.42
600 3.79 3.70 3.67 3.48
700 3.84 3.77 3.73 3.53
800 3.90 3.82 3.78 3.58
900 3.95 3.84 3.84 3.62
1000 3.99 3.89 3.88 3.66
1100 4.03 3.93 3.93 3.70
1200 4.09 3.96 3.97 3.73
Today is my lucky day. I just figured out more functions of my tripple power supply from BK. If I switch it to parallel I get double the current, so I can run led's at 1 amp now. I also found that I don't have to buy a new multimeter because I forgot that my Fluke 73 has an upgraded board which makes it a 77. I can measure current. So I had to play to see what the Seoul P4 I built would do. :twothumbs I'm impressed. Looks like about a third more light output. I ran the tripple K2 setup I built to use as a helmet light at 1000mA and the voltage drop across the led's started off at 11.8volts then as it warmed up, about ten minutes, the voltage droped and leveled off at 10.8 volts. I stuck an ice pack under the housing and the voltage worked it's way back up a couple of tenths of a volt but that's about it. At least I can do accurate calculations on run time and battery options without having to guess now.
Would one of you guys recommend a light meter for me now so I can get data. I need data.
