I have two floodlights in my storefront, and i'm looking to replace the Halogens with something more economical.
Anyone have any experience with these?Thanks in advance for any input!
I am not sure what type of store you have, but something to consider is that LED light is not the same as halogen light, it looks different. This might not matter to you at all if you just want light, but there are certain types of LED products designed to have better quality of light, though the prices on these are higher, and the options may be limited.
I have one of these "high CRI" LED floodlights. The light has a much warmer feeling than regular LED, and also makes wood colors and skin tones look better. This might be important if it is being used in a coffee shop or restaurant. It is still not
quite the same as halogen light, but should be perfectly adequate for most commercial uses.
But if the inside of your store is already being lit by fluorescent lighting, I would not waste your money on better lighting. It really depends on what type of store. Perhaps I am a little eccentric, but I just love halogen lighting, and suspect the insides of all the department stores where I am are going to look more greyish and dead when they switch out all their halogen spotlights with LED replacements. But I understand how LED makes commercial sense, with the lights being on all the time, using less electricity, and not having to replaced so frequently. Half the customers will not even notice.
Anyone have any experience with these? Are the LED reliable? I'm thinking that the fluorescent ones would give out more light, but i don't see too many of them offered on the market (in contrast with LEDs)
Yes, the LED should be reliable, assuming it is from a reputable brand and not one of the very cheap ones. Again, we cannot really be entirely sure that all the LED products will really live up to their long claimed lifetimes because these LED products have only really become widely available in the last two years, so consumers have not had the time yet to see if they prematurely fade out or stop working.
i noticed that there are both LED and Fluorescent lamps that will fit right in the ones I have now.
With fluorescent, it is difficult to concentrate much light output into a small area. For spot lighting, fluorescent just does not make much sense compared to LED. I would imagine the fluorescent ones are quite a bit bigger and bulkier, either that or have much lower light output.
