If I thought it was worth the investment, then I'd market my chargers (I've got 2 designs.....one USB fixed value using the LTC4053 and the other discrete design utilizing a buck regulator with both voltage feedback and current to get the CC/CV charge process. That one has a pot where I can set the termination voltage to whatever I like.
Sorry for the late reply. Yes i use the max lipo gauge to read the voltage as i have them lying around, or you can just use analog input from one of the arduino pin and some voltage devider. The max chip communicates through IIC interface with the arduino. In recent changes i also add current monitoring using alegro hall sensor and report the current back to lcd.@rizky_p: Do you use the Arduino and the LiPo gauge just to monitor the charging process and give feedback on the LCD?
4.25V is still safe, but not good for battery lifetime.Hi,
I'm using a DX version of this board. The problem is its termination appears to be at <50ma and at 4.25v or so.
I've tried a 0.5ohm resistor in series when charging and that seems to drop the termination voltage to safer levels.
Yes, it's safe to do. The TP4056 will normally terminate at C/10, so you have a 500mA board, right?The question is whether that's a safe modification and whether it could create issues in the constant current phase of charging?
...The TP4056 will normally terminate at C/10, so you have a 500mA board, right?
At 500mA, your 0.5Ohm resistor will drop 0.25V. So if the TP4056 targets 4.25V, it will already ramp down the charge current (enter the CV phase) at 4V battery voltage. The charge time will be a fair bit longer...
...4.25V is well within the TP4056 specs (4.137V - 4.263V). You may want to play the chip lottery and get a 5 or 10-pack of those boards. I have one that charges to 4.165V.
If I leave this TP4056 based charger board connected to a Li-ion/Li-Po cell, without input power, will it drain the cell?
If yes, how quick?
